I am using the thermocouple amplifier Adafruit_MCP9600.
In order to read the temperature I define an object (“basePlateTempSensor”) and I use “basePlateTempSensor.readThermocouple()”. It works.
But I want to do it differently. I create an object (“bottomChamberTemperature”) from the class “TemperatureControl”. Then I want to return the temperature value by using “bottomChamberTemperature.readTemperature()”.
I get 0 and sometime, the program crash.
Can someone tell me why?
Appreciate your help,
Cyril
The main.cpp:
// Sub-functions
#include <headers.hpp>
/*#include <Wire.h>
#include <Adafruit_I2CDevice.h>
#include <Adafruit_I2CRegister.h>
#include "Adafruit_MCP9600.h"*/
Adafruit_MCP9600 basePlateTempSensor;
TemperatureControl bottomChamberTemperature(HEATER_PIN, basePlateTempSensor);
if (! basePlateTempSensor.begin(i2c_temp_mat)) {
Serial.println("Sensor not found. Check wiring!"); //todo: make a special screen for this error
while (1);
basePlateTempSensor.setADCresolution(MCP9600_ADCRESOLUTION_18);
basePlateTempSensor.setThermocoupleType(MCP9600_TYPE_J);
basePlateTempSensor.setFilterCoefficient(3);
basePlateTempSensor.setAlertTemperature(1, 30);
basePlateTempSensor.getAlertTemperature(1);
basePlateTempSensor.configureAlert(1, true, true);
basePlateTempSensor.enable(true);
bottomChamberTemperature.init();
Serial.print(bottomChamberTemperature.readTemperature());
TemperatureControl.hpp:
#ifndef _H_TEMPERATURE
#define _H_TEMPERATURE
class TemperatureControl
private:
int m_heaterPin;
Adafruit_MCP9600 m_temperatureSensor;
public:
TemperatureControl(/* args */);
TemperatureControl(int heaterPin, Adafruit_MCP9600 temperatureSensor);
~TemperatureControl();
int readTemperature();
TemperatureControl.cpp:
#include <TemperatureControl.hpp>
TemperatureControl::TemperatureControl(/* args */){}
TemperatureControl::TemperatureControl(int heaterPin, Adafruit_MCP9600 temperatureSensor){
this->m_heaterPin = heaterPin;
this->m_temperatureSensor = temperatureSensor;
int TemperatureControl::readTemperature(){
int laminatorBasePlateTemperature = m_temperatureSensor.readThermocouple();
return (laminatorBasePlateTemperature);
TemperatureControl::~TemperatureControl(){}
