Hi, i need suggestions to the book (portuguese)
1 | INTRODUÇÃO | 3 |
1.1 | AWS IOT | 3 |
1.2 | AMAZON ALEXA | 4 |
1.2.1 | SKILL | 4 |
1.3 | AMAZON AWS LAMBDA | 5 |
1.4 | OS TRÊS JUNTOS | 5 |
2 | INSTALAÇÃO ARDUINO PARA O EVK-NINA-W1 | 6 |
2.1 | CONFIGURANDO IDE DO ARDUINO | 8 |
2.2 | TESTE SEU PRIMEIRO EXEMPLO | 12 |
2.2.1 | COMPILE E CARREGUE | 12 |
2.2.2 | EXECUTE O EXEMPLO BLINK | 16 |
3 | AMAZON WEB SERVICES | 18 |
3.1 | AWS IOT | 18 |
3.2 | AMAZON ALEXA | 19 |
3.3 | LAMBDA | 19 |
4 | OPERACIONALIDADE | 20 |
4.1 | ENTENDENDO A ESTRUTURA DA AMAZON WEB SERVICES | 20 |
5 | CRIANDO UMA SKILL PARA A AMAZON ALEXA | 22 |
5.1 | DIAGRAMA DE ATIVIDADES | 22 |
5.2 | PASSO-A-PASSO | 22 |
5.3 | RELAÇÃO ALEXA X LAMBDA | 54 |
5.3.1 | INVOCATION | 54 |
5.3.2 | INTEND | 55 |
5.3.3 | FUNÇÃO E SLOTS | 56 |
5.3.4 | LAMBDA E AWS IOT – PUBLICAÇÃO DADOS | 57 |
5.3.5 | LAMBDA E AWS IOT – LEITURA | 57 |
5.3.6 | WELCOME | 58 |
6 | ACESSANDO A COISA (AWS IOT) | 60 |
6.1 | HORNBILL | 60 |
6.2 | WIFI CLIENT SECURE | 64 |
6.3 | PLATFORMIO | 72 |
7 | CRIANDO UM EXEMPLO PARA IOT AWS | 80 |
7.1 | PROGRAMANDO EM ARDUINO O EVK-NINA-W1 | 80 |
7.2 | PASSO-A-PASSO | 81 |
7.3 | CHAMANDO O ALEXA | 84 |
7.4 | ACENDENDO OU APAGANDO LÂMPADA NO EVK-NINA-W1 | 87 |
7.5 | RETORNANDO A TEMPERATURA PARA O ALEXA | 91 |
7.6 | TESTANDO ALEXA COM EVK-NINA-W1 | 100 |
7.7 | BREAKOUT DE BAIXO CUSTO | 102 |
7.8 | CONSTRUINDO UM SISTEMA COMPLETO COM SENSOR DE UMIDADE E TEMPERATURA | 106 |
7.8.1 | DTH22 | 106 |
7.8.2 | LIB PARA ACESSO AO DHT22 | 106 |
7.8.3 | CONEXÃO NO BREAKOUT | 108 |
7.8.4 | UTILIZANDO ALEXA PARA OBTER A TEMPERATURA E UMIDADE | 109 |
7.8.5 | PROGRAMA ALEXA E LAMBDA | 111 |
7.8.6 | HARDWARE | 118 |
7.8.7 | INVOCAÇÃO, INTENÇÃO E FRASE | 118 |
7.9 | CUSTOS DA AMAZON | 120 |
7.10 | PEDIDOS DE PLACAS KITS | 120 |
7.11 | VIDEOS YOUTUBE | 120 |
8 | CLIENTE MQTT.FX TOOL | 121 |
8.1 | CONFIGURAÇÕES E TESTES | 121 |
9 | ARQUIVOS UTILIZADOS NESTE EXEMPLO | 127 |
Thank you!
