I’m about to embark on a project built around anSTM32F44 which I think is part of the nucleo F446ZE. It’s an initial exploration to try a multi tasking RTOS, which I have an application for, if I can get it to work. Picking a board is not easy as there are so many, but I’ve kind of settled on this board from a functions perspective, although I would say there are probably many others…
My questions are:
1 when I create a new project in PIO and pick a board, it has two - the 446 RC and the 446RE Can I pick one of these and expect things to work with the ZE ? I’m new to 32 bit stuff and don’t know the meaning of the suffixes.
2 Will I be able to debug and if so are key features such as breakpoints, step in /over, watches etc available?
thanks for help,
Paul
You can choose the board nucleo_f446ze according to the docs. That’s the exact board you have.
You can use the command line tools to search:
pio init -b pio boards f446ze
This results in:
Platform: ststm32
ID MCU Frequency Flash RAM Name
nucleo_f446ze STM32F446ZET6 180MHz 512KB 128KB ST Nucleo F446ZE
HTH
Cheers,
Norm.
thanks Norm, for some reason when I tried in the gui the board didn’t appear. It does now, probably me.
wrt debugging, in the PIO.ini I found this link to help
https://docs.platformio.org/page/projectconf.html
and when I explored it, there is a debug section:
; Debug options
debug_tool = custom
debug_server =
JLinkGDBServer
-singlerun
-if
SWD
-select
USB
-port
2331
-device
STM32F103C8
so if I change the device to STM32F446ZE, will that provide debugging facilities?
thanks
Paul
On the page linked in my first reply you get all the details of setting up for your board. This link will take you to the debugging section.
I’m more of an AVR “specialist” I’m afraid.
HTH
Cheers,
Norm.
