HI,
I have notice that when use “patformio ci” - command to build sources,
- you must place extra_scripts.py inside source dir not near ini file
- explicitly address file within src/ folder for example extra_scripts = src/extra_script.py
I think this is a bug ,because when you use “platformio run” option you don’t need this complicated method
My project directory structure is like this:
Project_dir ----> platformio.ini, readme.md, licenses.txt
|/Source_dir —> Sources .cpp .ino .h .hpp … etc.
|/Libraries —> custom libs, and place for project dependent lib_defs
|/include
|/shared
I have tried to put this file in every subfolder, shared,Libraries,lib etc. , with no success every time i got error “Missing SConscript: extra_script.pi”
