having issues while running adafruit mlx90614 library on energia but same library works perfect in arduino ide. help needed…
We can’t really help you if you don’t specify which board you’re compiling for, which platformio.ini
you’re using, what version of the Energia core you’re using in the Arduino IDE, what code you’re running and what the expected vs actual execution results are.
error:
i am using energia based coding scheme in platformio
code description: the library used is adafruit MLX90614 which is contactless thermometer sensor library. its gives temperature in Fahrenheit scale and also ambient temperature.
