I’m unable to compile example sketch from Adafruit_ST7789 library. It uses Adafruit GFX. During compile process I receive errors like this:
.pio\libdeps\d1_mini_pro\GFX Library for Arduino\src\Arduino_TFT.cpp: In member function 'virtual void Arduino_TFT::drawChar(int16_t, int16_t, unsigned char, uint16_t, uint16_t)':
.pio\libdeps\d1_mini_pro\GFX Library for Arduino\src\Arduino_TFT.cpp:1120:1: error: a15 cannot be used in asm here
*** [.pio\build\d1_mini_pro\lib114\GFX Library for Arduino\Arduino_TFT.cpp.o] Error 1
How to resolve this problem.
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini_pro.html
PLATFORM: Espressif 8266 (2.6.3) > WeMos D1 mini Pro
HARDWARE: ESP8266 80MHz, 80KB RAM, 16MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
Found 35 compatible libraries
|-- <Adafruit ST7735 and ST7789 Library> 1.6.1
| |-- <Adafruit GFX Library> 1.10.6
| | |-- <SPI> 1.0
| | |-- <Adafruit BusIO> 1.7.2
| | | |-- <Wire> 1.0
| | | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <GFX Library for Arduino> 1.0.7
| |-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <Adafruit seesaw Library> 1.3.1
| |-- <Wire> 1.0
| |-- <SPI> 1.0
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <Wire> 1.0
|-- <SPI> 1.0
|-- <Wire> 1.0
