This is hopefully a simple issue but I cannot figure it out. Trying to build anything for an Adafruit Feather M0 board (even the default main.cpp file) I get the following error:
Processing adafruit_feather_m0 (platform: atmelsam; board: adafruit_feather_m0; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/adafruit_feather_m0.html
PLATFORM: Atmel SAM (6.0.1) > Adafruit Feather M0
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
- framework-arduino-samd-adafruit 1.6.5
- framework-cmsis 2.50400.181126 (5.4.0)
- framework-cmsis-atmel 1.2.0
- toolchain-gccarmnoneeabi 1.90301.200702 (9.3.1)
Found 19 compatible libraries
Compiling .pio\build\adafruit_feather_m0\FrameworkArduino\TinyUSB\Adafruit_TinyUSB_ArduinoCore\tinyusb\src\portable\nxp\transdimension\dcd_transdimension.c.o
Assembler messages:
Fatal error: can't create .pio\build\adafruit_feather_m0\FrameworkArduino\TinyUSB\Adafruit_TinyUSB_ArduinoCore\tinyusb\src\portable\nxp\transdimension\dcd_transdimension.c.o: No such file or directory
*** [.pio\build\adafruit_feather_m0\FrameworkArduino\TinyUSB\Adafruit_TinyUSB_ArduinoCore\tinyusb\src\portable\nxp\transdimension\dcd_transdimension.c.o] Error 1
Appears to be an issue with TinyUSB? I believe everything is up to date.
Thanks in advance!
-Wyatt
