I am trying to use the CLUE board from Adafruit. A simple HelloWorld code (Serial.println(“HelloWorld”)) worked fine, however, when I added deps adafruit/Adafruit Arcada Library@^2.5.0 and adafruit/Adafruit Sensor Lab @ ^0.4.2, the compiler complained that it can’t find Adafruit_GFX.h which was included from Arcada. I looked in the .pio/libdeps all the dependencies of Arcada and Sensor Lab were there including Adafruit_GFX
Anyone know why?
[env:adafruit_clue_nrf52840]
platform = nordicnrf52
board = adafruit_clue_nrf52840
lib_deps = adafruit/Adafruit Arcada Library@^2.5.0
Below are the error messages
Found 29 compatible libraries
|-- <Adafruit Arcada Library> 2.5.0
|-- <Adafruit Sensor Lab> 0.4.2
Compiling .pio/build/adafruit_clue_nrf52840/src/main.cpp.o
Compiling .pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada.cpp.o
Compiling .pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada_Alerts.cpp.o
Compiling .pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada_Config.cpp.o
In file included from .pio/libdeps/adafruit_clue_nrf52840/Adafruit Arcada Library/Adafruit_Arcada.cpp:1:0:
.pio/libdeps/adafruit_clue_nrf52840/Adafruit Arcada Library/Adafruit_Arcada.h:9:10: fatal error: Adafruit_GFX.h: No such file or directory
* Looking for Adafruit_GFX.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_GFX.h"
* Web > https://platformio.org/lib/search?query=header:Adafruit_GFX.h
#include <Adafruit_GFX.h>
compilation terminated.
*** [.pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada.cpp.o] Error 1
In file included from .pio/libdeps/adafruit_clue_nrf52840/Adafruit Arcada Library/Adafruit_Arcada_Alerts.cpp:1:0:
*** [.pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada_Alerts.cpp.o] Error 1
In file included from .pio/libdeps/adafruit_clue_nrf52840/Adafruit Arcada Library/Adafruit_Arcada_Config.cpp:1:0:
*** [.pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada_Config.cpp.o] Error 1
=================================================== [FAILED] Took 3.32 seconds ===================================================
The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
> Executing task: platformio run --target upload <
Processing adafruit_clue_nrf52840 (platform: nordicnrf52; board: adafruit_clue_nrf52840; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/adafruit_clue_nrf52840.html
PLATFORM: Nordic nRF52 (4.4.1) > Adafruit CLUE nRF52840
HARDWARE: NRF52840 64MHz, 243KB RAM, 796KB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, jlink, stlink)
- framework-arduinoadafruitnrf52 1.1900.200603 (19.0)
- tool-bossac-nordicnrf52 1.10866.191129 (1.8.66)
- tool-openocd 2.1000.200630 (10.0)
- tool-sreccat 1.164.0 (1.64)
Found 55 compatible libraries
Compiling .pio/build/adafruit_clue_nrf52840/lib09d/Adafruit Arcada Library/Adafruit_Arcada_Filesystem.cpp.o
