The library it asks for is in the folder. I even made a new folder with that name with a copy of that file. PIO is ignoring my /lib folder.
But at the end of this error message is points to a different file. Is that another error or part of this bogus library error?
Okay, they weren’t all where I thought they were, but they’re all in one folder now. It’s refusing to see Adafruit_I2CDevice.h. I’ve restarted PIO several times to see if it would recognize, but no.
> Executing task in folder BLE_BME_680_WeMos: C:\Users\joema\.platformio\penv\Scripts\platformio.exe run <
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 1.12.4 > WeMos D1 MINI ESP32
Found 31 compatible libraries
|-- <Adafruit BME680 Library> 1.1.1
| |-- <Adafruit Unified Sensor> 1.1.4
| |-- <Adafruit GFX Library> 1.10.0
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <Adafruit SSD1306> 2.3.1
| | | |-- <SPI> 1.0
| | | |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0.1
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <ESP32 BLE Arduino> 1.0.1
|-- <SPI> 1.0
|-- <Wire> 1.0.1
Compiling .pio\build\wemos_d1_mini32\libed0\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
Compiling .pio\build\wemos_d1_mini32\libed0\Adafruit GFX Library\Adafruit_MonoOLED.cpp.o
Compiling .pio\build\wemos_d1_mini32\libed0\Adafruit GFX Library\Adafruit_SPITFT.cpp.o
Compiling .pio\build\wemos_d1_mini32\libed0\Adafruit GFX Library\glcdfont.c.o
In file included from lib\Adafruit GFX Library\Adafruit_GrayOLED.cpp:20:0:
lib\Adafruit GFX Library\Adafruit_GrayOLED.h:30:32: fatal error: Adafruit_I2CDevice.h: No such file or directory
* Looking for Adafruit_I2CDevice.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_I2CDevice.h"
* Web > https://platformio.org/lib/search?query=header:Adafruit_I2CDevice.h
compilation terminated.
In file included from lib\Adafruit GFX Library\Adafruit_MonoOLED.cpp:20:0:
lib\Adafruit GFX Library\Adafruit_MonoOLED.h:30:32: fatal error: Adafruit_I2CDevice.h: No such file or directory
Compiling .pio\build\wemos_d1_mini32\libebe\Adafruit SSD1306\Adafruit_SSD1306.cpp.o
*** [.pio\build\wemos_d1_mini32\libed0\Adafruit GFX Library\Adafruit_MonoOLED.cpp.o] Error 1
*** [.pio\build\wemos_d1_mini32\libed0\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o] Error 1
==================================================================================================== [FAILED]
After I finally wrote this post and fiddled some more, I restarted and all the libraries are found. In fact, no problems were found until I ran the build again.
'overflow in implicit constant conversion [-Woverflow] 418,20
This is the line:
} else {
gas_resistance = NAN;
return true;
Here’s the whole code. I’m blending a BLE Hello World with a BME 680 environmental sensor with an OLED:
* @file Adafruit_BME680.cpp
* @mainpage Adafruit BME680 temperature, humidity, barometric pressure and gas
* sensor driver
* @section intro_sec Introduction
* This is the documentation for Adafruit's BME680 driver for the
* Arduino platform. It is designed specifically to work with the
* Adafruit BME680 breakout: https://www.adafruit.com/products/3660
* These sensors use I2C to communicate, 2 pins (SCL+SDA) are required
* to interface with the breakout.
* Adafruit invests time and resources providing this open source code,
* please support Adafruit and open-source hardware by purchasing
* products from Adafruit!
* @section author Author
* Written by Ladyada for Adafruit Industries.
* @section license License
* BSD license, all text here must be included in any redistribution.
#include "Adafruit_BME680.h"
#include "Arduino.h"
//#define BME680_DEBUG
/** Wire object **/
TwoWire *_wire = NULL;
/** SPI object **/
SPIClass *_spi = NULL;
/** These SPI pins must be global in order to work with underlying library **/
int8_t _BME680_SoftwareSPI_MOSI; ///< Global SPI MOSI pin
int8_t _BME680_SoftwareSPI_MISO; ///< Global SPI MISO pin
int8_t _BME680_SoftwareSPI_SCK; ///< Globak SPI Clock pin
/** Our hardware interface functions **/
static int8_t i2c_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data,
uint16_t len);
static int8_t i2c_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data,
uint16_t len);
static int8_t spi_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data,
uint16_t len);
static int8_t spi_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data,
uint16_t len);
static uint8_t spi_transfer(uint8_t x);
static void delay_msec(uint32_t ms);
// PUBLIC FUNCTIONS
* @brief Instantiates sensor with i2c.
* @param *theWire
* optional Wire object
Adafruit_BME680::Adafruit_BME680(TwoWire *theWire)
: _cs(-1), _meas_start(0), _meas_period(0) {
_wire = theWire;
_BME680_SoftwareSPI_MOSI = -1;
_BME680_SoftwareSPI_MISO = -1;
_BME680_SoftwareSPI_SCK = -1;
_filterEnabled = _tempEnabled = _humEnabled = _presEnabled = _gasEnabled =
false;
* @brief Instantiates sensor with Hardware SPI.
* @param cspin
* SPI chip select.
* @param theSPI
* optional SPI object
Adafruit_BME680::Adafruit_BME680(int8_t cspin, SPIClass *theSPI)
: _cs(cspin), _meas_start(0), _meas_period(0) {
_spi = theSPI;
false;
* @brief Instantiates sensor with Software (bit-bang) SPI.
* @param cspin
* SPI chip select
* @param mosipin
* SPI MOSI (Data from microcontroller to sensor)
* @param misopin
* SPI MISO (Data to microcontroller from sensor)
* @param sckpin
* SPI Clock
Adafruit_BME680::Adafruit_BME680(int8_t cspin, int8_t mosipin, int8_t misopin,
int8_t sckpin)
_BME680_SoftwareSPI_MOSI = mosipin;
_BME680_SoftwareSPI_MISO = misopin;
_BME680_SoftwareSPI_SCK = sckpin;
false;
* @brief Initializes the sensor
* Hardware ss initialized, verifies it is in the I2C or SPI bus, then
* reads calibration data in preparation for sensor reads.
* @param addr
* Optional parameter for the I2C address of BME680. Default is 0x77
* @param initSettings
* Optional parameter for initializing the sensor settings.
* Default is true.
* @return True on sensor initialization success. False on failure.
bool Adafruit_BME680::begin(uint8_t addr, bool initSettings) {
_i2caddr = addr;
if (_cs == -1) {
// i2c
_wire->begin();
gas_sensor.dev_id = addr;
gas_sensor.intf = BME680_I2C_INTF;
gas_sensor.read = &i2c_read;
gas_sensor.write = &i2c_write;
} else {
digitalWrite(_cs, HIGH);
pinMode(_cs, OUTPUT);
if (_BME680_SoftwareSPI_SCK == -1) {
// hardware SPI
_spi->begin();
} else {
// software SPI
pinMode(_BME680_SoftwareSPI_SCK, OUTPUT);
pinMode(_BME680_SoftwareSPI_MOSI, OUTPUT);
pinMode(_BME680_SoftwareSPI_MISO, INPUT);
gas_sensor.dev_id = _cs;
gas_sensor.intf = BME680_SPI_INTF;
gas_sensor.read = &spi_read;
gas_sensor.write = &spi_write;
gas_sensor.delay_ms = delay_msec;
int8_t rslt = bme680_init(&gas_sensor);
#ifdef BME680_DEBUG
Serial.print("Result: ");
Serial.println(rslt);
if (rslt != BME680_OK)
return false;
#ifdef BME680_DEBUG
Serial.print("T1 = ");
Serial.println(gas_sensor.calib.par_t1);
Serial.print("T2 = ");
Serial.println(gas_sensor.calib.par_t2);
Serial.print("T3 = ");
Serial.println(gas_sensor.calib.par_t3);
Serial.print("P1 = ");
Serial.println(gas_sensor.calib.par_p1);
Serial.print("P2 = ");
Serial.println(gas_sensor.calib.par_p2);
Serial.print("P3 = ");
Serial.println(gas_sensor.calib.par_p3);
Serial.print("P4 = ");
Serial.println(gas_sensor.calib.par_p4);
Serial.print("P5 = ");
Serial.println(gas_sensor.calib.par_p5);
Serial.print("P6 = ");
Serial.println(gas_sensor.calib.par_p6);
Serial.print("P7 = ");
Serial.println(gas_sensor.calib.par_p7);
Serial.print("P8 = ");
Serial.println(gas_sensor.calib.par_p8);
Serial.print("P9 = ");
Serial.println(gas_sensor.calib.par_p9);
Serial.print("P10 = ");
Serial.println(gas_sensor.calib.par_p10);
Serial.print("H1 = ");
Serial.println(gas_sensor.calib.par_h1);
Serial.print("H2 = ");
Serial.println(gas_sensor.calib.par_h2);
Serial.print("H3 = ");
Serial.println(gas_sensor.calib.par_h3);
Serial.print("H4 = ");
Serial.println(gas_sensor.calib.par_h4);
Serial.print("H5 = ");
Serial.println(gas_sensor.calib.par_h5);
Serial.print("H6 = ");
Serial.println(gas_sensor.calib.par_h6);
Serial.print("H7 = ");
Serial.println(gas_sensor.calib.par_h7);
Serial.print("G1 = ");
Serial.println(gas_sensor.calib.par_gh1);
Serial.print("G2 = ");
Serial.println(gas_sensor.calib.par_gh2);
Serial.print("G3 = ");
Serial.println(gas_sensor.calib.par_gh3);
Serial.print("Heat Range = ");
Serial.println(gas_sensor.calib.res_heat_range);
Serial.print("Heat Val = ");
Serial.println(gas_sensor.calib.res_heat_val);
Serial.print("SW Error = ");
Serial.println(gas_sensor.calib.range_sw_err);
if (initSettings) {
setTemperatureOversampling(BME680_OS_8X);
setHumidityOversampling(BME680_OS_2X);
setPressureOversampling(BME680_OS_4X);
setIIRFilterSize(BME680_FILTER_SIZE_3);
setGasHeater(320, 150); // 320*C for 150 ms
} else {
setGasHeater(0, 0);
// don't do anything till we request a reading
gas_sensor.power_mode = BME680_FORCED_MODE;
return true;
* @brief Performs a reading and returns the ambient temperature.
* @return Temperature in degrees Centigrade
float Adafruit_BME680::readTemperature(void) {
performReading();
return temperature;
* @brief Performs a reading and returns the barometric pressure.
* @return Barometic pressure in Pascals
float Adafruit_BME680::readPressure(void) {
performReading();
return pressure;
* @brief Performs a reading and returns the relative humidity.
* @return Relative humidity as floating point
float Adafruit_BME680::readHumidity(void) {
performReading();
return humidity;
* @brief Calculates the resistance of the MOX gas sensor.
* @return Resistance in Ohms
uint32_t Adafruit_BME680::readGas(void) {
performReading();
return gas_resistance;
* @brief Calculates the altitude (in meters).
* Reads the current atmostpheric pressure (in hPa) from the sensor and
* calculates via the provided sea-level pressure (in hPa).
* @param seaLevel
* Sea-level pressure in hPa
* @return Altitude in meters
float Adafruit_BME680::readAltitude(float seaLevel) {
// Equation taken from BMP180 datasheet (page 16):
// http://www.adafruit.com/datasheets/BST-BMP180-DS000-09.pdf
// Note that using the equation from wikipedia can give bad results
// at high altitude. See this thread for more information:
// http://forums.adafruit.com/viewtopic.php?f=22&t=58064
float atmospheric = readPressure() / 100.0F;
return 44330.0 * (1.0 - pow(atmospheric / seaLevel, 0.1903));
* @brief Performs a full reading of all 4 sensors in the BME680.
* Assigns the internal Adafruit_BME680#temperature,
* Adafruit_BME680#pressure, Adafruit_BME680#humidity and
* Adafruit_BME680#gas_resistance member variables
* @return True on success, False on failure
bool Adafruit_BME680::performReading(void) { return endReading(); }
unsigned long Adafruit_BME680::beginReading(void) {
if (_meas_start != 0) {
/* A measurement is already in progress */
return _meas_start + _meas_period;
uint8_t set_required_settings = 0;
int8_t rslt;
/* Select the power mode */
/* Must be set before writing the sensor configuration */
/* Set the required sensor settings needed */
if (_tempEnabled)
set_required_settings |= BME680_OST_SEL;
if (_humEnabled)
set_required_settings |= BME680_OSH_SEL;
if (_presEnabled)
set_required_settings |= BME680_OSP_SEL;
if (_filterEnabled)
set_required_settings |= BME680_FILTER_SEL;
if (_gasEnabled)
set_required_settings |= BME680_GAS_SENSOR_SEL;
/* Set the desired sensor configuration */
#ifdef BME680_DEBUG
Serial.println("Setting sensor settings");
rslt = bme680_set_sensor_settings(set_required_settings, &gas_sensor);
return 0;
/* Set the power mode */
#ifdef BME680_DEBUG
Serial.println("Setting power mode");
rslt = bme680_set_sensor_mode(&gas_sensor);
return 0;
/* Get the total measurement duration so as to sleep or wait till the
* measurement is complete */
uint16_t meas_period;
bme680_get_profile_dur(&meas_period, &gas_sensor);
_meas_start = millis();
_meas_period = meas_period;
bool Adafruit_BME680::endReading(void) {
unsigned long meas_end = beginReading();
if (meas_end == 0) {
return false;
int remaining_millis = remainingReadingMillis();
if (remaining_millis > 0) {
#ifdef BME680_DEBUG
Serial.print("Waiting (ms) ");
Serial.println(remaining_millis);
delay(static_cast<unsigned int>(remaining_millis) *
2); /* Delay till the measurement is ready */
_meas_start = 0; /* Allow new measurement to begin */
_meas_period = 0;
#ifdef BME680_DEBUG
Serial.print("t_fine = ");
Serial.println(gas_sensor.calib.t_fine);
struct bme680_field_data data;
// Serial.println("Getting sensor data");
int8_t rslt = bme680_get_sensor_data(&data, &gas_sensor);
return false;
if (_tempEnabled) {
// Serial.print("Temp: "); Serial.println(data.temperature / 100.0, 2);
temperature = data.temperature / 100.0;
} else {
temperature = NAN;
if (_humEnabled) {
// Serial.print("Hum: "); Serial.println(data.humidity / 1000.0, 2);
humidity = data.humidity / 1000.0;
} else {
humidity = NAN;
if (_presEnabled) {
// Serial.print("Pres: "); Serial.println(data.pressure, 2);
pressure = data.pressure;
} else {
pressure = 0;
/* Avoid using measurements from an unstable heating setup */
if (_gasEnabled) {
if (data.status & BME680_HEAT_STAB_MSK) {
// Serial.print("Gas resistance: "); Serial.println(data.gas_resistance);
gas_resistance = data.gas_resistance;
} else {
gas_resistance = 0;
// Serial.println("Gas reading unstable!");
} else {
return true;
int Adafruit_BME680::remainingReadingMillis(void) {
int remaining_time = (int)_meas_period - (millis() - _meas_start);
return remaining_time < 0 ? reading_complete : remaining_time;
return reading_not_started;
* @brief Enable and configure gas reading + heater
* @param heaterTemp
* Desired temperature in degrees Centigrade
* @param heaterTime
* Time to keep heater on in milliseconds
bool Adafruit_BME680::setGasHeater(uint16_t heaterTemp, uint16_t heaterTime) {
gas_sensor.gas_sett.heatr_temp = heaterTemp;
gas_sensor.gas_sett.heatr_dur = heaterTime;
if ((heaterTemp == 0) || (heaterTime == 0)) {
// disabled!
gas_sensor.gas_sett.heatr_ctrl = BME680_DISABLE_HEATER;
gas_sensor.gas_sett.run_gas = BME680_DISABLE_GAS_MEAS;
_gasEnabled = false;
} else {
gas_sensor.gas_sett.heatr_ctrl = BME680_ENABLE_HEATER;
gas_sensor.gas_sett.run_gas = BME680_ENABLE_GAS_MEAS;
_gasEnabled = true;
return true;
* @brief Setter for Temperature oversampling
* @param oversample
* Oversampling setting, can be BME680_OS_NONE (turn off Temperature
* reading), BME680_OS_1X, BME680_OS_2X, BME680_OS_4X, BME680_OS_8X or
* BME680_OS_16X
bool Adafruit_BME680::setTemperatureOversampling(uint8_t oversample) {
if (oversample > BME680_OS_16X)
return false;
gas_sensor.tph_sett.os_temp = oversample;
if (oversample == BME680_OS_NONE)
_tempEnabled = false;
else
_tempEnabled = true;
return true;
* @brief Setter for Humidity oversampling
* @param oversample
* Oversampling setting, can be BME680_OS_NONE (turn off Humidity
* BME680_OS_16X
bool Adafruit_BME680::setHumidityOversampling(uint8_t oversample) {
return false;
gas_sensor.tph_sett.os_hum = oversample;
_humEnabled = false;
else
_humEnabled = true;
return true;
* @brief Setter for Pressure oversampling
* @param oversample
* Oversampling setting, can be BME680_OS_NONE (turn off Pressure
* BME680_OS_16X
bool Adafruit_BME680::setPressureOversampling(uint8_t oversample) {
return false;
gas_sensor.tph_sett.os_pres = oversample;
_presEnabled = false;
else
_presEnabled = true;
return true;
* @brief Setter for IIR filter.
* @param filtersize
* Size of the filter (in samples).
* Can be BME680_FILTER_SIZE_0 (no filtering), BME680_FILTER_SIZE_1,
* BME680_FILTER_SIZE_3, BME680_FILTER_SIZE_7, BME680_FILTER_SIZE_15,
* BME680_FILTER_SIZE_31, BME680_FILTER_SIZE_63, BME680_FILTER_SIZE_127
bool Adafruit_BME680::setIIRFilterSize(uint8_t filtersize) {
if (filtersize > BME680_FILTER_SIZE_127)
return false;
gas_sensor.tph_sett.filter = filtersize;
if (filtersize == BME680_FILTER_SIZE_0)
_filterEnabled = false;
else
_filterEnabled = true;
return true;
* @brief Reads 8 bit values over I2C
uint16_t len) {
#ifdef BME680_DEBUG
Serial.print("\tI2C $");
Serial.print(reg_addr, HEX);
Serial.print(" => ");
_wire->beginTransmission((uint8_t)dev_id);
_wire->write((uint8_t)reg_addr);
_wire->endTransmission();
if (len != _wire->requestFrom((uint8_t)dev_id, (byte)len)) {
#ifdef BME680_DEBUG
Serial.print("Failed to read ");
Serial.print(len);
Serial.print(" bytes from ");
Serial.println(dev_id, HEX);
return 1;
while (len--) {
*reg_data = (uint8_t)_wire->read();
#ifdef BME680_DEBUG
Serial.print("0x");
Serial.print(*reg_data, HEX);
Serial.print(", ");
reg_data++;
#ifdef BME680_DEBUG
Serial.println("");
return 0;
* @brief Writes 8 bit values over I2C
uint16_t len) {
#ifdef BME680_DEBUG
Serial.print(" <= ");
while (len--) {
_wire->write(*reg_data);
#ifdef BME680_DEBUG
Serial.print("0x");
Serial.print(", ");
reg_data++;
#ifdef BME680_DEBUG
Serial.println("");
return 0;
* @brief Reads 8 bit values over SPI
static int8_t spi_read(uint8_t cspin, uint8_t reg_addr, uint8_t *reg_data,
uint16_t len) {
#ifdef BME680_DEBUG
Serial.print("\tSPI $");
// If hardware SPI we should use transactions!
_spi->beginTransaction(
SPISettings(BME680_DEFAULT_SPIFREQ, MSBFIRST, SPI_MODE0));
digitalWrite(cspin, LOW);
spi_transfer(reg_addr | 0x80);
while (len--) {
*reg_data = spi_transfer(0x00);
#ifdef BME680_DEBUG
Serial.print("0x");
Serial.print(", ");
reg_data++;
digitalWrite(cspin, HIGH);
_spi->endTransaction();
#ifdef BME680_DEBUG
Serial.println("");
return 0;
* @brief Writes 8 bit values over SPI
static int8_t spi_write(uint8_t cspin, uint8_t reg_addr, uint8_t *reg_data,
uint16_t len) {
#ifdef BME680_DEBUG
spi_transfer(reg_addr);
while (len--) {
spi_transfer(*reg_data);
#ifdef BME680_DEBUG
Serial.print("0x");
Serial.print(", ");
reg_data++;
#ifdef BME680_DEBUG
Serial.println("");
return 0;
static uint8_t spi_transfer(uint8_t x) {
return _spi->transfer(x);
// software spi
// Serial.println("Software SPI");
uint8_t reply = 0;
for (int i = 7; i >= 0; i--) {
reply <<= 1;
digitalWrite(_BME680_SoftwareSPI_SCK, LOW);
digitalWrite(_BME680_SoftwareSPI_MOSI, x & (1 << i));
digitalWrite(_BME680_SoftwareSPI_SCK, HIGH);
if (digitalRead(_BME680_SoftwareSPI_MISO))
reply |= 1;
return reply;
static void delay_msec(uint32_t ms) { delay(ms); }
That overflow is the only remaining error.
I still want to know about those last three error lines mean.
This is where gas_resistance is declared. Does ‘overflow’ mean it needs a bigger data type, like a long?
performReading();
Try swapping those lines around. I’m not sure it will help, but always best to get the Arduino stuff in before anything that might need it.
Is gas_resistance
a float
? NAN
is.
Cheers,
Norm.
