So, I added a new framework, by copying the arduinoavr one and changing it’s name to test the procedure.
I followed @ivankravets instructions from this topic. I’m pretty sure I did all the steps. And I also added support for the new framework in the project’s local libs.
But when I try to build my project with this new framework (the board has the framework added to it’s list aswell), I get two errors:
1- Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Bridge
(this goes on for all the libs)
2- Error: Nothing to build. Please put your source code files to '/Users/gianpaolo/Dev/Xenitt/SOTEM/testemisor/src'
If I change the environment to a board using framework-arduinoavr like the UNO, it builds fine. I’ don’t know what I’m missing.
This is the full build output in any case:
14:10:03 Building the project | Processing...
[ Deviot 1.2.5 ] testemisor.ino
[Thu Oct 20 14:10:03 2016] Processing sotem (platform: atmelavr, board: sotem, framework: sotem)
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/EEPROM
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Esplora
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Ethernet
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Firmata
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/GSM
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/HID
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Keyboard
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/LiquidCrystal
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Mouse
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/RobotIRremote
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Robot_Control
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Robot_Motor
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/SD
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/SPI
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Scheduler
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Servo
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/SoftwareSerial
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/SpacebrewYun
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Stepper
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/TFT
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Temboo
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/USBHost
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/WiFi
Framework incompatible library /Users/gianpaolo/.platformio/packages/framework-sotem/libraries/Wire
More details about "Library Compatibility Mode": http://docs.platformio.org/en/stable/librarymanager/ldf.html#ldf-compat-mode
Collected 3 compatible libraries
Looking for dependencies...
Project does not have dependencies
Error: Nothing to build. Please put your source code files to '/Users/gianpaolo/Dev/Xenitt/SOTEM/testemisor/src' folder
========================== [ERROR] Took 0.76 seconds ==========================
================================== [SUMMARY] ==================================
Environment sotem [ERROR]
Environment uno [SKIP]
14:10:04 ERROR | it took 1.04s
Help much appreciated! Thanks!
